Handheld Tuner Showdown
OK. I am going to get either the Diablosport Predator or the Superchip Flashpaq. I can't decide. :cheers: both have the same features and performance gains, but SC is 30$ cheaper. someone with real life numbers help me out here.
Could try a search, there's tons of info regarding handhelds, including a comparison between the 2 you mentioned. Here are a few I found just on the first page of the search results.
http://www.gm-trucks.com/forums/index.php?...ic=67252&hl
http://www.gm-trucks.com/forums/index.php?...ic=63604&hl
http://www.gm-trucks.com/forums/index.php?...ic=65184&hl
http://www.gm-trucks.com/forums/index.php?...ic=54621&hl
http://www.gm-trucks.com/forums/index.php?...ic=69083&hl
http://www.gm-trucks.com/forums/index.php?...ic=62686&hl
Or, just save some time reading, and flip a coin. You know, if you've already decided to skip the custom tuned route. :cheers:
check E-bay for NEW predator units, there's a place called west-coast-auto-performance that sells NEW predators for around $306 depending on your model.
predator also has forum specifcly for GM-gas users, superchips does not.
Predator allows you to view live data, and in some applications log live data and upload it to your computer. superchips does not
Predator allows you to tune and modify multiple perameters, superchips does not.
check out the forum www.diablosport.com
The original superchips handheld and the Flashpaq, also made by superchips, are 2 completely different units. Superchips does have a dedicated forum and website for the Flashpaq. The flashpaq also has data logging capabilities, such as 0-60 times, air/fuel data, etc. And you can modify various parameters within the Flashpaq - however, they are limited to somewhat more basic items than the Predator. Such as shift pressure, shift points, speed limiter, etc.
    ottogriffin
    ottogriffin
  • Who's Online   3 Members, 0 Anonymous, 608 Guests (See full list)
