Outside Air Temp Sensor?
Heysdad
Hello guys,
We have a 2005 Envoy SLT with the auto dual temp controls. My outside air temp has been stuck on 77 degrees for at least a few days now. It's 93 here today and has been for weeks now, and that thing is stuck on 77. :lol:
The indication works fine for adjusting the cabin temp but when it reverts back to outside air temp...It's back to 77..... :chevy:
Where is the sensor and is there a reset that can be done?
About 1 month ago we got a new radiator installed at the dealer, could that have anything to do with it?
Thanks for the help... :lol:
I believe it is behind the front bumper under the grill support. I dont know about your Envoy but on my Suburban and my Silverado both had instructions in the owners manual about how to reset the compass/temperature display.
Alright thanks guys...
I looked in the owners manual and there's nothing about a reset. It just says that after the engine is off for 3 hrs it shows the last temp until it gets a new reading.....Ahhhh Yea. That would make sense......How could it not.....?
I'll take a look behind the grill to see if there is anything loose....If I can find the sensor that is.
If anyone else out there has info please help...It's driving me crazy now knowing it's not working. :cool:
Look under the right parking light (remove it - there's a tab on the inboard edge you push in) - You should see a "U" shaped metal clip attached to the wire harness that has the sensor clipped in it. The other spot to look is in on the front of the radiator. There is a square tube support that runs across up and then back down that holds the hood latch. On the left side of it there is a temp sensor for the OAT.
Thank you very much..I'm going to look right now.
OK...I think I found it. When standing in front of the grill looking at the engine, it's to the right, behind the grill and next to the hood release. It looks like a small gray sugar cube with a electrical connector coming off it with 2 wires..... Does that sound about right?
That's it -
Thanks for the help. That was it. I found the connector not installed all the way. It pushed on with a good click now.
I guess when they did my radiator change they did not get it back on all the way.
It's working great now. :cool:
    timcpeters
    timcpeters
  • Who's Online   4 Members, 0 Anonymous, 1,190 Guests (See full list)
