Wheel Bearing Replacement
cev103
I just replaced the left side wheel bearing on my girlfriends 2002 Trailblazer and now the ABS light on the instrument panel is on (the light was not on before replacing it). Is it a bad bearing or sensor, or does something need to be reset on the vehicle?
Yeah, that was the first thing I checked..........I'm thinking the sensor is bad?
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 779 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
