Parnelli Dirt Grips Or Mickey Mtz's?
Its time for new tires for my truck and I am really tore between these two. Most of my driving will be highway but I work on a farm so I do get off road some as well. Mostly fields and dirt/gravel roads. Occasionally mud but never more than rim deep on purpose anyway, I have been out checking fields and sunk pretty good. Im currently running Mastercraft Courser MT's and they have been great im gonna end up with about 40,000 miles out of them but I just want to try something different. Ill be getting them in a 285/75R16 for my stock wheels and I am just really torn between the dirt grips and the MTZ's. Both are close in price and I have heard that they both will go atleast 40,000 miles.
What about the Cooper Discoverer STT or the GoodYear MTR? I have had the MTR's and they are a great tire and I'm currently running the Cooper STT's in a 35/12.50/20 and they are sweet!!! If you don't like either of those then I'd go with the Mickey Thompson MTZ's. I don't have any experience with the PJ's so I can't give you an opinion on those.
Well I have had a couple friends that had bad experiences with the goodyears so I dont want them, and with the coopers Ive always been a lil worried about the cooper company Ive heard bad things about them.
I have the Mickey-T MTZs with about 8k on them, and they're wearing really well. They're good on road for a mud tire, and they pull really really well in the mud. They're actually manufactured by Cooper, and they have a very similar tread to the STT, which I've heard lots of good things about as well. I know a guy with about as many miles on his STTs as I have on my MTZs, and they're wearing almost identically. I wouldn't be worried about Cooper, they're a solid company.
I also know a guy who has had a couple different sets of the PJ's, and he loved them. They aren't a very good tire in the mud from what I've heard though, just a very aggressive looking AT tire, but they wear well.
The PJs are a good looking tire but like the others I don't have any actual experience. Ditto for the Coopers. We don't have cooper dealers around here. (that I am aware of anyway).
Firestone makes a Destination MT that is super aggressive and still rides well. It gets rave reviews and sells for about 175 in your size on Tirerack.com.
The Goodyear MTRs are significantly more expensive than the Mickey MTZs, and are horrible in rain or snow. The MTZs do better in both due to the siped tread blocks (same for the STTs).
I loved my MTZs on my TJ and i can't wait to get a set on the Silverado.
Those of you with MTZ's or who have friends that have MTZ's how many highway miles did you get out of them or how many do you currently have, and those of you still running them bout how much tradlife you got left?
Mine were pretty new when i sold the TJ, but it's not odd for TJ guys to get 60-70k out of them. Keep in mind though, that TJs weigh about half what a 1/2 pickup does.
I have a little over 8,000 miles on mine, and they have at least 80-85% tread left, which puts them on pace to get a little over 40,000 miles, which is right on par with what I've heard people getting with these trucks. If you're willing to spend the money on them, I say go for it. :D
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
