08 Sierra Wheels To Tb Ss Wheels
ok my friend told me that i could put the trailblazer SS wheels on my 08 sierra, is this true?? :lol:
i thought that the lug patterns were differnt? he was saying it would look sick and opinions? :lol:
Bolt pattern should be the same 6 x 5.5" or 6x139.7mm. Only thing is you need a 17 or larger diameter wheel.
ya i got the stock 20 on my sierra so i want to see if i could but the ss wheels on, that be hot
Easy, Paris. :lol: J/K.
I was under the impression that Trailblazers had a smaller 6 lug bolt pattern though, something like 6on4.5?
ACTUALLY, that is correct. I guess I didn't even pay attention to the whole Trailblazer bit. I just saw SS and went from there. These wheels will not fit a Silverado. They are 6X5 and the truck is 6X5.5.
Sorry for the confusion.
Good catch, Ranger.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
