2004 Silverado 4wd Fail
GMfan13
I have a 2004 Silverado 4wd. I was driving with Auto FWD, and suddenly the yellow button get off and a message of service 4wd appear. I already reset the message and it dissapear, but the control is not working anymore, I already change the control and it didn't work. What else can I do?
Thanks.
Thanks.
There is a TSB on this issue. I had a Tahoe 4wd Z71 with this exact problem and this service fixed it.
http://www.gm-trucks.com/forums/index.php?...ticle&id=52
Thanks.
What type of terrain were you driving on with a4wd?
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 812 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
