Help Needed Asap
I realize this may not be a priority thing but I figured this section gets read more then alot of other sections so Ifigured id post it here, but here is the issue at hand. This is on a 2002 GMC Sierra, I recieved from a good friend LED light bars (same thing as the Fire & Ice LED Lightbar from Plasmaglow, but only 8 inches rather then 60 inches) which are to be used on my mud flaps and because I am accepting them I am going to use them so they can see that I used em, I hooked em up to my 4 pin connector just to see if they worked but noticed a few problems with the rest of the truck, when I plugged em in and turned the turn signals on they worked fine, when I hit the brake lights they worked fine, 4 ways worked fine also, now when I turned my parking lights on and tried the turn signal it would click once to show it was working but then sorta freeze in the on position so in other words it would flash like once and then freeze, same for the other side, when I put the 4 ways on with the headlights on they clicked once and then froze, I also noticed when I turned the parking lights/headlights on the 3rd brake light lit up also, This is a first time issue with anything like this happening, anyone know what the problem is or may be ? I would like to maybe determine this issue ASAP because I was planning on installing them tommarow morning because they look pretty cool from what I saw.
The problem sounds like one of the lines are getting crossed (I did that a while back with the custom LED taillights). You might want to consider a taillight converter if you plan to run the stop/turn together with that LED strip. If not, then just tap into the turn signal wire and it should run from there with no issues (assuming you have everything properly connected and grounded)
    Patrick Fergy
    Patrick Fergy
  • Who's Online   4 Members, 0 Anonymous, 970 Guests (See full list)
