Really Ned Your Opinion Before I Order
I took my 08 Sierra to the hunting club yesterday and boy was I surprised to see how much mud was thrown upon the fenders and onto the steps since I put the Pro comp 305-65-17s on it. As some know, I had a problem with the tires rubbing inside the fender well right where the plastic fastener is so mud flaps that attach in this area are out of the question. Does anyone know of a mud flap that will fit my particular application? If not I'm going to have to look into fender flares. Any help would be greatly appreciated. Oh, I have searched for an answer for my problem but didn't find anything for my particular problem.
Thanks,
Ray
Thanks,
Ray
I had to replace my front mudflaps with some "flat" ones that are only about 1/8" thick and I had to modify them slightly right where that fastener that you removed is. I got them at the auto store for under $20 and I am sure I will be replacing them every couple of years or so since they are not the highest quality, but they are flat and they do the trick. I like the fender flares, but I do not like how they trap dirt underneath them because they are not sealed to the fender.
I can take a pic this evening if you'd like me to.
Thanks,
Ray
That would be great Jeff, I'd really appreciate it. I went to the dealership but the oem front flaps are way too thick in that area and would never work. I'll see what your's look like and probably head to autozone in the morning.
Thank you, keep em coming.
When I added my 285s to my truck I took off the flap itself and left the piece that adapted it to the fender flare. With that and my 5" oval step bars I only get a little mud on the truck. Seemed to work good for me but I think that Jeff had a pretty good I idea with the cheap flaps if you don't really want any mud.
Got a picture ?
{calling out} "NED!!!!"....."NED!!!"....Where is Ned when you need him?
:dunno: j/k, man...
I know, I know, Take you shots :D You can edit the message but not the topic :lol: . Go ahead, I deserve it.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
