Corvette Z06 Cam In A 5.3l
I just bought a 2008 2WD Silverado Crew Cab w/ 5.3L. Was told that you can install the Z06 cam and springs in the engine and pick up around 30 HP and not sacrifice MPG. Also told that the factroy ECM would compensate for the cam change after a few start/stop cycles. Sounds almost too good. Anyone done this swap? Of course there are warranty considerations. So if any GM people are reading this please toss in your 2 cents worth on this. Not looking to build a race truck. Just want some more HP. Considered the 6.0L but I understand they are gas hogs. I drove an '03 6.0L on a road trip recently and it definitely sucked the gas.
I'd look into a custom tune before tearing apart the motor. Do a search on here, you'll find plenty of info.
Welcome to the site, too. :rollin: We'll also need pictures of the truck. :sleep:
+1 Welcome! :sleep:
You can. You will only net about 10-15 horses. You will want to change the intake, heads and the Torque converter. Then get a tune. Once you change a cam, you move the whole rpm range around.
IMO since you 'just' bought a new truck, get a tune. No need to tear apart the motor for just a cam, unless you want to do it right.
I'm not so sure you can run a non AFM cam in an AFM engine. I'm pretty sure the AFM cams require a smaller base circle.
I did not want to put a tune on it. If it goes in for warranty they can see a tune, and they're looking. After the warranty, I'll be doing several changes. We have HP Tuner in our R&D department so I can play with that later. The cam sounded interesting as it would be hard to detect. I was told you can swap the cam without pulling the intake or radiator on the trucks. Just enough room to get it out without pulling the rad.
Good point on the AFM. That will require some research.
On changing intake, etc. I wouldn't think 15 HP would require a new torque converter. Am I missing something here? New intake and heads would probably increase HP even more but I wouldn't think they would be necessary. Once again, trying to keep the warranty issues in mind.
You don't think they'll notice the cam...? :)
I am not sure with the AFM also.
The Z06 cam is for an engine designed for high horsepower on a car. This is something the truck is not really engineered for. Our trucks are designed with torque in mind. When you swap in this cam, you are not just adding horse power, your moving the entire power band around. Cams can be tricky, why dont you come over to Here, and look around. There are numerous upon numerous threads relating to cams.
As for warranty issues, All GM has to do is put a scanner on the ECM and notice the parameters have been moved around to compensate for the cam. They will know. If you have HPT, play with it. Once you dial in the tables, you can do alot to really wake the 5.3 up. And if you have to go to the dealer, just load the stock tune, the dealer will never know.
i think they will detect the timing isnt the same or the firing order isnt the same with the cam.
What does a cam have to do with firing order or ignition timing? :D
They would know the calibration has been changed, just not what you did to it.
:D
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 2,835 Guests (See full list)
    • My 2015 1500 LTZ Silverado suddenly won't go into 4 x 4 low. It will go into 4 x 4 high.
    • Yep, just a quick reference point.    My main point being I’d do a thousand other things before I’d pay 10k for a transmission.    Speaking in ignorance cause I don’t look at these trucks, what is it worth? 20k?
    • I think users are going to want to pick their monitored parameters, which parameters they want to see first.    It should probably start with baseline at a minimum and adjust to learned, but be able to overlay baseline for comparison.   A simple severity level would be able to determine what type of alerting is appropriate or user selectable.    Why not use the OBD port though?   I think a phone connection would be a good idea, push notifications type deal.   Number 1 issue is having data is useless if you don’t know what the data should be under normal conditions.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Monday looks like a good day for the dealer to test an ac issue. Hopefully it all turns out good.
