2003 Rear View Mirror
Guest Riggs
Guest Riggs
Im trying to transplant a 2003 mirror into my 1997 GMC, i dont need everything to work.. i just like the looks. and its a little bit bigger.right now i have 3 wires
Black, Green, Pink/Red
My Rear view mirror has Compass, Auto Dimming....
the new one has like 8 wires....
Im looking for the compass which i have now, and auto dimming, and temp
so what wies would i have to hook up to get auto dimming, and the temp to work? it looks like there is a infrared in front to take temp and a little eye for dimming..i dont need the passenger air bag and other stuff i cant hook up in my truck..
Thanks.. (Would i be able to get a wiring diagram) or is that agaisnt rules now?
Guest Riggs
its comming off of this truck
so where would i find the temp sensor? or anything else i might need?
Thanks in advanced!!
Talk about the hard way to dismount a tire.
If I remember correctly (I had a 2003 Silverado SS) you need to make sure you get everything off the other truck stalk and all because the temp sensor is attached. The other wires are for the passenger air bag warning, and onstar( if it is an OnStar mirror).
You should clip the connector off of the wrecked truck and graft it in. Pink is +12, black(/usually yellow) is ground and cant remember what green is for.
Guest Riggs
it isnt an onstar mirror, i already clipped the connector with about 8 inches of wire so i can make it work with some sodering..
The temp. sensor is there (On the donor truck that is) I see it in the picture you posted (Look at the pic.,Theres a little spec of Blue,Thats it)
Its on the "V" brace below the auxiliary tranny cooler on the drivers side.
Since your truck already has the compass all you have to do is add the terminals into your existing mirror connector,I did the same thing with my '99,It had a compass but no outside temp.display....I got a mirror from an '01 (that had comp/temp display) Got the temp.sensor,and was able to get the temp sensor wiring harness by itself,so I just removed the terminals from my factory connector and installed them into the new harness.
I never did hook-up the part where the mirror would "un-dim" when put into reverse.
BTW....I assume thats a truck your Dad towed in?!?!
Guest Riggs
i towed that in...
so i would have to run wires from the temp sensor from the grille to the headliner and hook it up to what wires?
Thanks...
I would like the colors to
Power
Ground
Compass
And temp sensor wires
Guest Riggs
Alright i just went out and cut the temp sesnor off the truck
It has Black w/ White Stripe and a Green w/ White Stripe... and matchs up to wires on the mirror harness...
so i just need to know what the power and ground and compass wires are
please? and thanks in advance
Guest Riggs
anybody?
I need to know what the power and ground wires are,,, i can figure it out after that...
Please? Thanks?
Don't know if this will help or not since it's 02 wiring diagrams but the following is for the inside rearview mirror - w/ electrochromic, compass and outside temperature.
Pin 1 - Pnk - Ignition 1 voltage
Pin 2 - Blk - Ground
Pin 3 - Lt Grn - Backup Lamp Supply Voltage
Pin 4 - Gry - Automatic Day/Night Mirror Signal
Pin 5 - Pnk - Automatic Day/Night Mirror Low Reference
Pin 6 - Dk Grn/Wht - Ambient Air Temp Sensor Signal
Pin 7 - Blk/Wht - Low Reference
Guest Riggs
The colors for the Mirror are:
Lt Green
Dark Green
x - Green w/ White Stripe - Temp Sensor
Pink
Yellow
Black
x - Black w/ White Stripe - Temp Sensor
Blue
Grey
pink be power? and black ground?
Lt Green
Dark Green
Pink
Yellow
Black
Blue
Grey
Like I said, that's coming out of an 02 service manual....may have changed some for the 03. Maybe one of these guys that spent their hard earned money to buy a factory service manual for an 03 will actual open and try to give you some help on this one. I've actually got the onstar version in my truck and it's got a 16 pin connector. I would assume the power and ground might be correct though....pink on pin 1 and black. I think the compass function is built into the mirror itself at least on my truck. The wiring diagrams show nothing externally wired for that function.
Guest Riggs
btw wont i just be able to remove the torx screw and put the new mirror on?
or do i have to rip the mirror off the window?
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 1,137 Guests (See full list)
