Front Input Shaft/bearing
06silverado4.3ss
i have a 06 silverado with the 4.3v6 5sp. i have aslight howling noisy when i go to pull out and some times while i am rolling without my foot on the gas. as soon i as give more gas the noisy goes away. this only happens sometimes. any ideas? 55k
also if i rev the engine with the clutch in no noisy, but i i pull the clutch out about half way and rev the engine i get a ticking noisy. also this does this going down the road. but if i press the clutch in and rev no noisy.. this also happens sometime not always.
any ideas fixes would be appericated. thanks
Just replying so you know your computer is working! :lol:
Not up on the newer 5sp manual tranny's but I have the old NV3500 in my 88 Chevy. They are known for having bad input shaft bearings and the resulting noise. I thought GM had that under control in the mid 90's? Maybe not.
Could be the throw out bearing..but from my experience..it's probably the input shaft bearing. I installed (3) different NV3500 tranny's in this truck...and all of them make the same noise you describe. I just got used to the noise after about 40,000 miles.
There is a specific lube for the NV3500..but I mixed in some heavier stuff anyway...it's still holding up "and noisy".
My next truck will have a NV4500.
Take care
Ed
BTW: The entire tranny must be disassembled to replace the front bearing.
    timcpeters
    timcpeters
  • Who's Online   3 Members, 0 Anonymous, 1,257 Guests (See full list)
