Nelson Vs. Blackbear
I would like to say thanks to all who have posted their opinions and blackbear is the winner by a long shot. I have already recieved three emails from justin and i asked him a question but he hasnt had time to reply and im in need of an answer.
The 400 dollar deposit that is sent for the cables--- since the cost of the tune plus the PCM and TCM is 420 dollars he says that once you return the cables you get the deposit back. Is their any one who knows if he can keep the 400 dollar deposit and i sent him the rest as payment for the tune and modules. Can any-one answer this question for me.
Thanks guys
Thanks guys
I can't answer your question but I'm about 30 minutes away from you (New Bern) and the cable and scan tool came in yesterday. I hope to start doing some recording tomorrow. I'm sure Justin will get back with you shortly.
Thanks guys
man thats pretty cool let me know the difference. it would be awesome if we could share the cable and both get the tune done at the same time but i know that sh#t prolly wouldnt fly with him. How is yourMPG on that truck with the tires and all
Thanks guys
Naw, I don't think that Justin would appreciate that. Anyhow, I'm averaging around 16 mpg. My DIC says I'm getting 12mpg but it's wrong.
It is not a problem for you guys to share the cable. Just make sure that you label the tune logs correctly and you are good to go. PM me or Justin if you have any questions.
Now THAT is awesome customer service right there! You just got yourself a new customer. I'll be calling once I get enough $$ saved up.
THANK YOU!!
Agreed. Hopefully I'll be giving you guys a call sometime in the spring.
Now THAT is awesome customer service right there! You just got yourself a new customer. I'll be calling once I get enough $$$ saved up.
THANK YOU!!
The MINUTE Justin (or Jenna) let's me know the EFI Live handheld is available, I will be whipping out the credit card. But first I will need to send my computers back to Nelson to get them unlocked.
Sorry Jeff, no updates as of late. Justin talks to the EFILive folks on a weekly basis, so we will be sure to post up as soon as we hear anything.
As far as sharing cables, we have no problem whatsoever, just one of the folks will need to be responsible for the deposit. If you wanted to try to get others to share with you, so you can split the deposit cost, we have no qualms with you posting up on forums to get others to share.
Thanks Jenna! Looking forward to it. :dunno:
Thanks Jenna! Looking forward to it. :lol:
Just get off the wallet!!! I will buy the handheld too... :dunno:
    bellssn690
    bellssn690
  • Who's Online   5 Members, 0 Anonymous, 718 Guests (See full list)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
