Slow Starts With '05 Tahoe
Hi guys, this is my first post here, but I've been reading for a while.
I recently bought an '05 Tahoe/4x4/5.3L and it seems like it doesn't have enough power from a stop. Once it winds up (15-20 MPH and up) it has great power. While accelerating from a stop, it does seem to "lurch" back and forth a little. I'm wondering if it has to do with the traction control system reducing engine power? Or is it normal for these to lack low-end torque?
Thanks in advance.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
