Corsa Exhaust
I was wondering if anyone purchased a Corsa exhaust and ended up changing from either the Sport to Touring or from Touring to Sport? If so how much did just the muffler cost from Corsa? Thanks.
the only options corsa has for mufflers only are the db series(red or black volume levels). i looked for just a corsa sport muffler, i actually emailed corsa but got no response. then asked a local place that orders corsa and they said that the sport or touring catback system is all they sell(not just the muffler). check this out for more info:
http://www.corsaperf.com/CorsaDbMufflerSeries.aspx
Yep. I've had both. Search. -> http://www.youtube.com/omegafiler
It was cheaper to buy a whole new cat-back on eBay. Corsa wanted something like $600 just for the muffler. And that's because they don't normally sell them separately - unless it's the smaller db series.
I figured the muffler would be fairly expense but not that much. I guess I will keep what I have for now. Thanks for the info and the vid.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 905 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
