Do Cranked Keys Harm Truck Other Than Harsh Ride?
I have a 05 Av with 'ReadyLift' keys that lifted it about 1" to 1-1/2", my mechanic recommended not going any more when he put them on a couple of years back. I would like to get more lift out of it, I think the bars have aged some as it has settle some since we did the ReadyLift keys.
My question is if the keys are maxed out for height, does it hurt the front axles etc. or just adversely affect the ride? The Suspension Maxx brand of keys have come out since I did mine and they claim to have fixed the harsh ride issue with their design so I was considering getting them if I was confident that maxing out the keys for maximum lift will not harm the truck mechanically.
Any thoughts? Thanks in advance. Jeff
All re-indexed torsion keys will affect the ride negatively, there is NO way around it, they all just crank the torsion bars more. And your mechanic is right, if you go over about 1.5", you will start to wear out parts like CVs, tie rod ends (inner and outer), Pitman arms, idler arms, and ball joints. If any of the steering components fail while you're driving, you'll lose control of the truck. Sounds fun, right? Don't cheap out, you'll end up paying more in the end. If you want height, go with a true suspension lift (new cross members, differential drop brackets etc.), or get a body lift. The adjustment bolt on the torsion bars are meant to adjust the height of the vehicle slightly, not be a cheap 'lift kit'.
I definately wouldn't go much higher. I would like to crank up the keys on my truck simply to level it out some - I love the raked stance but it's just a bit TOO raked for me.
One thing to remember, any time you tinker with the geometry of the front suspension, it's a good idea to get an alignment done or you chance tearing up your tires. If you've got old/worn parts, you may hear funny noises or feel funny things, but there's not much you can do about that.
What those guys said.
Oh...And...Get longer shocks, it'll help TONS with the harshness. Or you can shim your factory ones down a bit. Same effect.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
