Vortec 5300 Swap
I have a 74 Vette with no motor.  I have recently come across a Vortec 5300 and am thinking of installing it.
Although I have a few questions.
1.
Are the motor mounts in the vortec blocks the same as a regular 350 block?  (I do not believe so)  From what I understand an LS1 derivative's mounts is a little different but there are kits one can buy to bolt an LS1 into 350 motor mounts?  Same with a 5300?  I assume the mounts on an LS1 are the same as a 5300?
2.
The Vortec 5300 is externally balanced?  It does not have a hole in the flywheel, for a manual tranny?  To bolt this motor up to a Muncie or Super T10 one would have to buy a new flywheel?
3.
Will the 5300 Overbore
From 96mm->99mm
From 3.780in->3.900in
I have heard this can be done but this is a very large boring.
These are the dementions for a regular LS1.
4.
Is there a stroker kit currently out for the 5300's.
5.
Can the computers in a 5300 an EPROM, can they be reprogrammed on the fly?
6.
What is the advertised duration and lift on a stock 5300?
7.
Is there a difference between a 1999 & 2000 5300?  Are all LM7's the same, I have found different horsepower output numbers for this engine.
8.
Any thing else that could be helpful guys I would greatly appreciate.  If you can just comment on a few it would help me alot.
Thanks Again
[email protected]
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
