How Do You Remove Grill Emblem On Gmc?
I'm wanting to paint the red on the emblem to black but can't get the emblem off. I didn't pull too hard cause I didn't want to break it.SO, How do you remove the GMC Emblem on a 08 Sierra?Plus, I was thinking of putting a billet grill and I want the emblem to say on but I don't like the grill with the cutout. I've heard that you can put the emblem on the full grill with 3m tape or something. Anyone done or have pics of this?Thanks
It should be held on from the back with a couple of speed nuts if it's like the others I have had. I know that's how the Chevy bowtie came off on my last truck.
I felt back there but didn't feel any.... Tomorrow I'll get out the mirror and give it a look.
Thanks
No nuts, just clips. You can see from this picture the slots the clips are in. You just need to depress the clips and it pops right out.
    Policeoff01
    Policeoff01
  • Who's Online   4 Members, 1 Anonymous, 745 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
