New Grille On The Way
Wouldn't you get the same result just adding the billet insert? I think it will look good.
Yes, but I need an entire new grille anyways. My old grille is peeling, you can see it in my sig pic.
Alrighty then. I'll make sure to get the old girl all nice and shiny before snapping a few pics.
I just received my UPS tracking info, should be here tomorrow!
Damn I love UPS, and FedEx, and DHL.....
When are the new wheels, tires and shackles showing up? :lol:
Would you like to donate?
I have the first lug nut covered. Who else is gonna step up? :lol:
dang dude, what happened to your grill thats on the truck now? I think it will look good... You should paint the bowtie!
R E A D, READ.
I will donate a set of those light up valve stems!
Thanks, but I think the guy with the two exhaust tips welded together will like them more.
You'd give him stuff right off of your truck? Wow, you are a true friend. :lol:
