by pass items
I have been seeing on e bay that there is a manifold water bypass kit that claims to give 10-15 hp or somthing like that and an egr bypass plate that does the same numbers. Has anyone used or done this, and is a spacer block worth it on our throttle assembly and what can you gain, just looking for cheaper mods that work.
A almost free mod is the throttle body hot water bypass and there is no need to buy a kit. I used a piece of metal tubing (gas line) and two small hose clamps. Disconnect small coolant hoses from both sides of throttle body, install metal tubing to reconnect two hoses and tighten hose clamps. I also used rubber vaccum caps on the two hose connection tubes on the throttle body. You will lose a small amount of coolant so replinish your reservoir.
On EGR equipped engines the pipe that goes into the passenger side of the manifold from the EGR valve can be pulled out of the manifold and the protrusion that sticks into the manifold just to the rear of the throttle body can be cut off so it does not interfer with the air flow from the throttle body. I do not think you can remove the EGR valve on an EGR equipped engine without setting a code and the SES light.
Yep, what PDQrado said is correct.  The kit on e-bay includes items that you could get at any autoparts store for very little money.
People try selling crazy stuff on there.  I seen someone selling directions on how to get the "change engine oil" light to go out!  :D
    • I agree with Tim.  As tech heavy as engines are these days, no way I’d be an early buyer of the new 6.6.  Of course, I bought my ‘26 Denali w/the 6.2 after dumping my Tundra with it’s defective 3.5 liter imploding engine disaster, so I’m a little gun-shy.  That said, my 6.2 has been rock solid.  I don’t drive it like I do my BMW Z4 M40i, but I don’t baby it either.  I got a V8 for a reason.  But I’m averaging 18 around town and 22 highway.  I have seen 24 highway as well when I wasn’t loaded up heavy.  Considering my Tundra with the twin turbo V6 only got 14.5 in town and 17 on the road, I’ll take the 6.2 all day, every day.  If I were you, I’d grab a ‘26 while you can.  Inventories are probably gonna start dropping and I’ll bet the deals will start looking sweeter as well.
    • I am curious if anyone has figured out a way to add an hard button AUX or 360 Camera switch to the center row of switches. I have a 2021 AT4, and want to split the hill decent button and add a 360 camera button so that you don't have to go into the center display and locate the camera functionality, etc...   My father's 2024 Yukon XL AT4 and it has a hard button, see below. I found this thread on the Yukons, but it seems like there may not be a part number for the 2021 sierras. https://www.gm-trucks.com/forums/topic/255339-adding-hard-button-for-camera-on-2021/ Anyone else figured this out. Seems like it would need to be a custom switch!   I am getting ready to install the auto stop/start eliminator, so would be nice to knock them out at once.     Upvote1Downvote0Go to comments
    • Looks like the entire state is burning. 😬
    • Through the years it hasn't been my typical method as I tried to drop oil on an engine that was hot from having been worked, however that was not always practical and had to fire up a unit and let it warm up reasonably well and drop the oil when I had the time to do it but am referring to not only vehicles but a variety of farm equipment and highway tractors etc. However on a vehicle where one is crawling under it and the exhaust is nearby to ones body and if wanting to pull the plug without danger of being hit with boiling hot oil or attempting to remove a HOT oil filter, its sure safer and easier to not have everything smoking hot and can remove the filter right away when under the vehicle and let it all drain. Of course its not the end of the world if a bit of oil stays in the engine that might have eventually found its way out, I like to get out as much as possible but any oil changes that take place in shops would rarely be sitting around for very long at all before the plug is thrown back in and filter slapped on and oil poured in and sent out the door quick like. There would be very little time spent ( assuming they even did it ) in starting the engine with oil to fill the filter, then waiting to verify the level on the stick. A good reason to check ones oil level shortly after a shop changed the oil on a vehicle just to make sure its correct and to look under for any oil around the drain plug or filter.
    • Cool to see another Vermonter!
