Newb From Canada * Update *
TimoSLT
hey guys sorry for the 2nd post but i found out that you can't edit posts
soo here i will do it this way.
I'm lovin' the truck.
my 2008 Sierra and my dad's 2007 Chev
the 2008 is the SLT package with the 5.3
the 2007 is 2wd Vortec-Max need i say more.......
***** suggestions?????? *****
thanks again guys
Cheers :dunno:
Tim
2 Great lookin trucks :dunno: Although I am a bit partial to the Sierra.
You guys should race!!! haha :D .. No really, Window Tinting and sprayed in bed liners is where I like to start! IMO :shakehead:
:D Well I will be the first to admit his Sierra would smoke my Suburban. I believe my Silverado would give him a run for his money. :banghead:
Hey guys... thanks for the compliments on the trucks... i love my sierra and haven't regreted the purchase at all .. some future mods are coming down the pipe.. so i will get some pics of them when they happen.
i took off the front lip and added some bed rail protectors in prep for the tonneau cover... i am thinking the extang tri-fecta.. just for the ease of removal for putting a bike or some bigger in the bed of the truck.. my dad had lots of luck with the tri-fecta on his 97 chev WT...
thanks again guys for the compliments and suggestions..
:lol:
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,065 Guests (See full list)
