A/c Fan Speed Problem
waltfult
I have a 2006 Silverado extended cab with the v-6 engine. My problem is that when I place the fan speed control on the highest setting "5" the fan doesn't work. All the other settings from 1-4 work fine. wHAT IS THE PROBLEM?
Hi there and welcome to GM Trucks!
It could be that the switch has gone bad. Or the control unit for the fan.
