Need Some Feedback
Hey all I need some feedback on this item here. http://www.jegs.com/i/JET/561/70706/10002/-1 I have a 2003 tahoe 4.8 with roughly 147K miles on it at the moment. 85% of which are all highway. Never had any problems with my truck other than a fuel pump at 100K, and a bad HUB bearing burning out on me. I change my oil every 3000 miles since i purchased, as well as the tranny fluid twice a year. Would this be a good upgrade to prolong the life of my tranny possibly to 250K before needing a rebuild or would this cause more stress on the well broken in drivetrain???
thanks
Red29 :D
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
