Pre-runner?
ok first of all i dont want a prerunner or a prerunner life i want one that puts the tires out a bit and makes the front a little hight like a pre runner
i want to put a pre runner like lift on my truck but how do you know what kits are like prerunners someone told me that fabtechs are but i dont know
any help or suggestions would be helpful ya i did search but not much on pre runners here didnt help much
ok i want to put a pre runner lift on my truck but how do you know what kits are prerunners someone told me that fabtechs are but i dont know
FabTech is the way to go. I've lifted two of mine that way and their stuff is very well designed and built. Even over time, the alignments stay perfect. A lot of companies can't do that.
Prerunner trucks have extended a-arms for long travel and that is what make the tires stick out so far. You can buy rims with little backspacing to make them stick out. Fabtech is a good company especially in quailty but it is like any other 6in drop bracket lift kit (its not a prerunner kit). I guess you could install a 6in lift and leave out either the block or add-a-leaf to make the front higher than the rear.
if you have about 7 grand this is what i would recommend 2wd Long Travel Lift Kit If you don't have that kind of money I would suggest just going with the fabtech kit seeing as a fabtech kit will put your front tires out a little wider than stock. Also if you get rims with a little smaller backspacing
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 445 Guests (See full list)
