Screwed Up The Radio Head
Hello all,
Ok... I had a couple burned out light bulbs on the radio display so I decided to dig into it and replace the bulbs... Heck, the bulbs in the HVAC control were easy enough, why not the radio? Big mistake... So, the radio comes out easy enough and the whole control unit comes away from the radio itself, if you are careful doing it... There is the problem, careful, is the key word. One of the small wiring connections came appart and it's pretty much impossible to repair. One of the bulbs that are out happens to be inside the knobs, so that's another problem...
My question to the forum is this. Where can I get a new display unit? or the part number for the animal? Don't need the whole radio/cd/tape/sat unit, just the control plate... Can anyone point me in the right direction?
It's the radio display found on a 2005 Silverado w/cd, cassette tape and sat. Bose Sound System
Thanks!
Andy
I would check on Ebay/Craigslist and gmpartsdirect.com
I thought of ebay after I thought of this forum... Problem solved... A cool place I found, www.replacmentradios.com
Andy
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
