Exactly What Is The California Package?
California Package
Includes Vortec 5.3L SFI V8 engine with Active Fuel Management (displacement on demand), iron block, 315 hp @ 5200 rpm and 338 lb-ft of torque @ 4400 rpm, 20" x 8.5" 5-spoke machined aluminum wheels, P275/55R20 touring blackwall tires, high performance suspension and steel spare, trailer hitch platform, electric trailer brake wire harness, 7-wire harness for park lamps, backup lamps, right turn, left turn, electric brake lead, battery and ground, independent fused trailering circuits attached to 7-way sealed connector, 7-way to 4-way trailer adapter, instrument panel jumper wiring harness for electric trailer brake controller, 1-way sealed connector for center high mount brake lamp, high capacity air cleaner, auxiliary transmission cooler and heavy-duty automatic locking rear differential. NOT AVAILABLE with L76.
I think the "high performace" suspension is GMs Z85 suspension package, but then again that's defined as a "trailering/handling" package, so I'm not 100% Here's the Info I could find on the Z85 off the GM site-
Suspension Package, , Handling/Trailering, heavy-duty, includes 46 mm piston monotube shocks and 34mm front stabilizer bar ( Z85 )
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
