Battery Light Flickers In Message Center When Driving
bsturn
Hi everyone, here's a stumper. I have a 2001 Chevy Silverado with a slight electrical problem. The battery light in the message center flickers on from time to time and sometimes stays on for about 30 seconds and goes out when ever the engine is running. I do think it's weather related. As soon as the temp seems to drop below 50 outside the problem seems to minimize and even go away for quite awhile. THE VOLTAGE is good. 14volts plus all the time. The volt gauge don't even flicker when the battery light comes on. I've checked with a volt meter and all the grounds for the engine are good. I know some friends that have 2003 and new chevys that have a dash cluster problem. They say the solder on the connector pins can be bad. Can anyone help. Low mileage truck that I bought new. I don't want to take to the dealer locally. They'll spend at least $300 or more of my money. The alternator charges fine and isn't grounding out that I know of. Thanks... Lots of luck with this one..
  • 10 months later...
I am getting the same thing right now. Really wierd. I cleaned all the ground connections and checked allternator output. All looks fine. Anyone know of any known problems. By the way, it's a 2001 Sierra extended cab 4x4
  • 2 months later...
I have the same problem with the battery light flickering. I have a 2002 Sliverado. The problem started about 4 years ago. It will not happen for weeks then it will start again. The dealer could not find a problem but charged me $90. Recently the battery died, it had a cracked case. That seemed like an unusual way to fail so I suspected overcharging. I have a voltmeter connected to the battery and alternator which I can monitor while driving but have found nothing unusual. A couple of years ago I had the instrument panel out and measured signals there but did not know enough about how the message center is controlled to find the problem. I'm currently trying to figure out how the message center gets it's signals so I can monitor them to see if there is a correlation between the light coming on and any of the signals. This is not easy.
Any tips would be appreciated.
  • 1 month later...
Hello,
Same problem here. I have been seeing this for a few years. It happens for a week or two then works fine for 6 months or more. When the battery light flinkers it shows no pattern. Replaced battery, chased the positive and grounds, checked connections and checked for codes........nothing to date has helped.
Looking forward to any feedback or thoughts.......
2001 GMC Sierra 1500 4x4 Extended Cab 5.3
Thanks,
Terry
  • 8 months later...
Wondering if anyone has come across a fix for this. From the list of people that responded initially, it looks like it's limited to 01 or 02 trucks.
My light still flickers intermittently with no ill effects. Just kind of annoying.
2001 GMC Sierra extended cab 4x4 5.3
  • 5 months later...
i have a 2002 2500HD 166,000+ miles. the battery light just started turning on and off in it. i agree it is very annoying, just as annoying as people to dont post solutions once they figure out their problem. anyway, anyone have anything on this???
pretty funny. i just read that last comment and was like heck yeah, that guy has it right on...of course it was me 11 months ago. i still havent been able to fix the issue ortherwise i would have posted a solution. i can tell you the issue wend away for 6 months or so and just surfaced a week ago and now its constant, i dont even know how much gas i have because it wont snap back to working. i've got to figure this out. any help out there? 2002 2500HD 185,000+.
have the battery tested ,dont think the 14v means its good,i just went thru this same thing with a 03 dirtmax at work,both batteries failed ,replaced ,drove forever and it was fine
have the battery tested and go from there
Might be a stupid suggestion, but have you checked the negative connection on the battery? I had an H3 and the lights started flickering on the expressway as I hit bumps...ended up being a loose negative connection on the battery.
Sent from my DROIDX using Tapatalk
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 515 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
