Fixing Wheel Bearings
whatever "fixing" ends up requiring...
An answer to one of my earlier posts, about noises coming from the rear of my 2002 Sierra 2500HD dmax, made me start thinking about possible problems with my wheel bearings. I'm a truck newbie, so I'm not sure what problems I might have, or how to detect them, but I did feel of the covers on the hubs of the wheels, afer I've been driving a while at high speed. One of them is noticeably hotter to the touch than the other 3. And this is true whether or not that side of the truck has been in the sun so the sun alone doesn't seem to be causing it. And the lug nuts are hot to the touch too, more than on the other 3 wheels. Am I in trouble, or headed that way?
If "yes", is this something I MUST take to a GMC dealer to get fixed, or could any reasonably qualified tire store type of place handle it?
At the moment, I'm on an extended trip towing my RV, and I'm not sure how long it would take any place to fix it, once they had the right parts, etc. Is it reasonable to expect that it could be done in a day, once a shop got started on it, or am I likely to have to leave the truck more than a day? Either way is ok; I just need to know how to plan...
Thx
I'd be willing to bet the heat you describe is much more likely to be from a brake. A lot of heat gets dissipated through the rotors into the hubs and wheels. It isn't uncommon for one brake to create more heat than the other because of a slightly hanging caliper slide or sticking caliper. If that much additional heat was because of the hub/bearing assembly, you'd be able to rock that wheel from the 6 and 12 o'clock positions (with it jacked up) and feel excess play in the bearing. Once it was that bad, I'd think the noise would be more noticeable than heat.
It's certainly worth having checked whether it is brake or bearing related... especially if you are towing... Just to be safe.
I would lean towards a brake issue too... That is not too uncommon on that year of truck.
Thx both of you who answered....now to my 2nd question: should I take it to a GMC dealer or can any competent tire/wheel/brake place help me out satisfactorily?
No reason a good independent shop couldn't have a look and solve it. Plus, you'll probably get out cheaper to boot.
Good luck.
    ballencd
    ballencd
  • Who's Online   3 Members, 1 Anonymous, 664 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
