2006 Silverado Rims/tires
Hey fellas I got a couple of questions regarding having an extra set of rims/tires for the summer of 2009. My uses in the summer for my truck are purely street (and maybe strip) as I have a 2WD.
I have been eyeing some 20" rims, mainly the MB Gunner 6 from MB Wheels:
http://www.discounttire.com/product/wheels/mbmgu6.am.xl.jpg
(Finish: Anthracite Machined)
and General Grabber UHP
http://www.discounttire.com/product/tires/genrh2.xl.jpg
(Size: 295/50R20XL 118V BSW)
I am wondering which size tire I should choose with those rims:
255/50-20
275/55-20
295/50-20
I raised the front of my truck 1 inch in the front with one of those coil spacers and dropped the rear of the truck with the 2" drop shackles. Should I be concerned with any rubbing on the front end with the 295/50-20s?
Also any suggestions for alternate rims and tires are appreciated with the following in mind:
*Nothing over 20"
*No Chrome or Chrome Plated Rims
*No Black Rims
*No Offroad Rims
*No All Season Tires
*No Tire Costing over $250.00 (per tire)
I am being picky as a motherf**ker but I figure if I am gonna spend $2000 by next summer, I might as well be picky.
Sorry Jeff, we Texans can have 20s on the trucks with no real problem. :thumbs:
Here we go again... :thumbs:
But really, both the wheel and tire look good to me.
With the 295/50-20 you suggest, I would suggest looking at either a 40 or 45 aspect ratio.
I like to use this tool when comparing wheel and tire size/aspect ratio combinations. link
I really like the Gunner 6s from MB Motoring. They're truly the wheels I wanted but I got the ones on my truck for a steal at $80/each shipped. As far as tire sizes, I can't help you a ton as I'm just not sure but your choice of wheels is nice. I believe Darkanion has those rims...you may ask him his thoughts on them and longevity. My MB wheels are perfect and shine as well as they did on the first day.
Jason, you are correct.. I'm running the chrome version of the MB Gunner 6's on my truck. I have had ZERO problems with them. One of the center caps rattles a little bit, at low speeds... So, I don't go slow. Problem solved! :thumbs:
Seriously, though, I think my wheels and I think the tires you've come up with would look good with them. I like that tread pattern.
I'm running 275/55's on mine. If you want something with a little more "look" to them, you might check to see if General makes those Grabber UHP's in a 285/50. I think if you go with 295's, you'd be more likely to run into issues with rubbing.
Thanks for the info, then I should be fine with the rubber not rubbing?
:D looks like we posted at the same time. If you dont mind, do you have a shot of your front tires and how close they come to the inner well? If not I might just go 275/55-20 or 285/50-20 if it does not rub....
:thumbs: looks like we posted at the same time. If you dont mind, do you have a shot of your front tires and how close they come to the inner well? If not I might just go 275/55-20 or 285/50-20 if it does not rub....
You're coming up for the tune, right? I'll be around, off & on, that whole weekend. Unless you're ordering before early December, you can take a look at the tires I have on the truck, the wheels, the clearances, etc. then.
I don't have any pictures of inner clearances. If you're ordering before December, though, I can probably get some for you, maybe this weekend, if the weather is cooperative.
No I plan to order these for my birthday in Jan of 2009 and have the tires early Feb 2009. Quick question, you have not had any issues with pitting have you?
Not that I've noticed. Now that the weather has cooled off some, I plan to get out and spend some good one on one time with each wheel, getting them all cleaned-up good, and polished up before our 2-3 wks of cold gets here. :thumbs:
I'll let you know if I find any problems.
I think those will look good. :D
Thanks Josh, I hope to have em soon and when I do, I plan to post TONS of pics...
  • 1 month later...
update: I went to Discount Tire yesterday and and was told that I can consider one of the following:
20x10 6x139.7:
http://cgi.ebay.com/ebaymotors/4-NEW-20x10...%3A1|240%3A1318
20x8.5 6x139.7
http://cgi.ebay.com/ebaymotors/4-NEW-20x8-...%3A1|240%3A1318
Both are the Anthracite Machined finish, both are from discounttiredirect (just on ebay) and both are for a set of 4 rims. The guy at the local discount store said that he would have to sell the exact same rim to me for $979.00. His reasoning behind this is Discount Tire (here locally in austin) said they were trying to get rid of the black MB wheels and had high demand for chrome/Anthracite Machined finish rims. I figure I can go online and save $200.00 bucks since these are what I want and both auctions contain free ground shipping to my home. My question is whether I can go with the 20x10 6x139.7 rims or the 20x8.5 6x139.7? Thanks for the clarifications.
I'd go with the 20x8.5's. Seems like you want a tire with at least some sidewall to it and with the wider wheels, you'll have to go with a lower profile tire IMO.
Go with the 8.5s, hands down. They have a 25mm positive offset, as opposed to the -25 mm offset on the 10" wide wheels. A 10" wide wheel with that much negative offset will stick out a freaking MILE.
EDIT: I think these are the 10" wide ones. Granted, they have 38s on them, but the lip is HUGE and they stick out about 5 miles. Looks tits on that truck, but not on a lowered 2wd. :ughdance:
http://www.gmfullsize.com/forum/showthread.php?t=128934
YUCK, I could use that lip as body cladding :rollin: 20x8.5's it is!
    FiLo
    FiLo
  • Who's Online   5 Members, 0 Anonymous, 655 Guests (See full list)
    • sorry to bump an old thread, im a bit clueless with this stuff, would these fit a 2019+ Silverado? https://wiperpro.com.au/products/chevrolet-silverado-wiper-blades mainly wondering if the beam shape stays planted at highway speed, thats what seems to let the factory ones down imo
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
