Labor Day weekend
NewbieZ71
I third that
Have a great holiday weekend everyone
Be safe
Ill be back late monday from a weekend of fishing
Shaners - are you actually going to get out of your truck for any festivities?  The kids may want to do something you know.....:wink:
im not i pull my truck down in our backyard (of our cottage) down by the lake.  Put some chairs in the bed and fish from back there.  At night the rear cargo light is awesome.  Roll the windows down and play some music.
Its gonna be a great weekend
In two 500 mile trips to Wyoming, via Utah,  in the last 10 days, I've seen gas prices go up 5-10 cents a gallon.  Hope everyone has a safe and not too costly, holiday weekend!
I'm back from Party Cove alive.
The one night I was the sober Chaufeur, I got rearended leaving the bar.
I did manage to cut my foot open on the prop of a boat.  I got 8 stitches and the doctor in the ER told me I couldn't get back in the water so I was to sit on the back of the boat and drink beer.  I followed his directions until I couldn't see straight.
**** that sucks
Sounds like my weekend.  I cut grass at our cottage.  Me and my dad were talking and i was standing on some RR ties next to the lake.  I forgot there was a bee nest in there.  Well next thing i know my dad says watch out.  Didnt help i got stung a few times on my achilles tendon.  Swelled up pretty bad.  Pain went straight to the bone.  After a few days only itching remains.  Never been stung in 21 yrs that ^*#(%# Hurt.
This was a bad long weekend for me.. Since we moved i had no time to sit around and relax.. It as all packing up and then trying to unpack everything before monday night came around..  Oh well there's always next year!
Steve
Your lucky your not allergic to them.. My allergies are bad enough that 1 sting could kill me if i didnt get my medication..  I ve been stung once in my life *knock on wood* i just hope it stays that way..  And of course what helps me even more is when your stung your supposed to take penicillen *SP* and of course i m allergic to that as well..  Oh well
