Lifting A 2500 Using Hd Suspension On A A Non Hd
Hey guys, I have an 02 2500 NON HD model. I dont want to put an aftermarket kit on it, but I do want to lift it up little. The HD models are as much a 2-3" taller than my truck, My truck sits like a half ton.
I bought the truck new, and it dose have heavy duty suspension, and oddly enough a plow package. I looked at the torsion bar tags, and they are the same part number as the HD model, but I dont know what parts are different. I suspect it's the spindle brackets, and some small lift blocks, but not entirely certain.
Can anyone tell me what parts I need to make this conversion,, and if you have them for sale from an after market lift conversion?
M
Put a 3" body lift on it...That's the easy way at least, as for suspension I think the HDs get their lift from a slightly taller frame and a 2" body lift.
The HDs don't have a BL, they just have a 2" taller frame, which makes them sit like they have a 2" BL (look in the rear wheel-well, there's no gap between the body and frame).
Yeah, I figured it was mostly the frame, even though the RPO sheet has something called a "2 inch body lift"...Maybe it refers to thicker bushings or taller body mounts?
IMO, If there was a body lift for the HD's it would be the ugliest thing ever seen... If I was doing a lift I would just do it right and do a 6" suspension lift...
But you have to have bigger tires first! :) Thats my goal! Tires+Lift
    Sothpaw27
    Sothpaw27
  • Who's Online   6 Members, 0 Anonymous, 563 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
