My Most Recent Purchase...
onac255
Got this thing about two weeks ago.
It's a 1999 "Freightshaker" Century with a 470hp 12.7L Detroit Diesel 60 series straight ten trans. and 3.58s in the rear ends.
This is what she looked liked last Sunday. The green visor is getting color matched and I'm am probably gonna throw on some nice decals/stripes to break up the white.
Any suggestions on the color schemes? I was thinking some red stripes but I'm not sure...
(I know she ain't much to look at but hey she gets the job done and my bills paid...)
Here is my other freightshaker all nice and spit shined...lol
Is it a 470 straight, or a 430/470 cruise power?
430/470 FTW! Supposedly one of the best detroit has ever made but its my first Detroit I have always had CATs so we will see.
Nice trucks
Thank you
how many miles do they have?
860K on the Century and the Kitty in the Classice is 1.3 Million and still running strong as ever. (preventative maintenance is key...)
There is a lot of mulah in them things arent there?
It ain't what it used to be but I do pretty good...
No, I will not make you a new sig. :jester:
Looks cool, but I don't know crap about them. :lol:
Lol I don't want a new sig until I clean her up a bit and get her ready for a photo shoot lol She ain't to pretty right now...
It definitely is a winner, send me the Serial #, it will start with a 06R0, and I will give you every bit of info Detroit has on it..warranty history, etc
Thanks Alaska I will get you that number when I get a chance.
The previous owner bought it from Arrow Trucking
Truck has a new head, turbo, compressors, radiator, clutch, and other misc. stuff.
She is in great shape and just needs some TLC and a good driver.
Right on...if you need anything for it let me know. I would email you the service manual but it's like 200 mb.
I know 60s inside and out
Awesome good to know. Yeah my mechanic really likes 60's I guess if I get 1MPG better than my cat I will like 60's too(the Kitty is averaging 6.72MPG...)
I just could not pass this deal up...it was way too good.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 874 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
