2006 Gmc Sierra "service 4wd"
rctrex
I have a 2006 Sierra 1500 CC with 75,000 mile. The Service 4WD message on the DIC. This started last spring along with the lights on the switch going out. Back then I took the switch out and apart. I cleaned the contacts on the switch and did not have the problem since. But with the cooler temperatures this fall it restarted, but the lights on the switch stayed on. I went ahead and replaced the switch, but I am still getting the message. It just stays in 2hi.
I called onstar and asked them to run the diagnostics to get the code, but they said there was no code returned.
I have read many treads on this site about replacing the encoder motor or the transfer case motor or different wiring harnesses. Can someone give me advice on where is the next most logical check since the truck is not showing a code? Thanks
Do not buy an encoder until you know for sure it's the problem. Up here in Canada the dealer wants $705 and aftermarket is $360. Sorry, that's all I can help. :rolleyes:
I called Onstar again to see if they could get a code, of course nothing showed up but then they transferred me to a diagnostics advisor and he said that Onstar will not pull codes from the transfer case. So I had a local shop check it for me and it came back with CO327-Encoder switch. So now I know what to replace, but I cannot find the part #. The local dealer wants over $600. Does anyone know the part number or where I can find it? Thanks!
Check this out @ AutozoneEncoder Motor,hope it helps
Gary
    Whit.the.COB
    Whit.the.COB
  • Who's Online   3 Members, 0 Anonymous, 1,236 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
