Timing Light Settings
Is there anything that needs to be disconnected, like the brown wire in the junction box, for the 89 model? I am just asking as I know that's the case with my 92.
--Mike
Correct
Theres a brown wire near the distributor on the firewall. Start the engine up with the wire unplugged and set your timing to 0* BTDC. Turn off the engine and re-connect the wire. Start her back up and the ECM should take over.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
