Cooling System
Well; fresh pot-'o-joe,nowhere-to-go!
Got great info from MS3Dale; went-to-finish..
DON'T have 17mm hex (have 18,15,16; bet there's one @ Sears..)
Auto-supply sold me wrong block-heater (will-fit '81-2k 6.2,8.1 DIESEL!)
Gotta get this unit up-n-running so,gonna put coolant back-in temporarily (managed to drain into a pretty-clean container,for once!) till i get the right pieces,later this week;
Question? Read somewhere (but can't find post/thread again,of course) about having to 'bleed' this closed system after i put coolant back-in..
Is there a specific procedure i need to-follow?
Here's a link for purging the cooling system.
http://www.gm-trucks.com/home/Technical/Ma...ing-system.html
Hey,THANX!
Filled via surge-tank to 'cold' mark,took for a spin; on-return,discovered it was a bit low (understandable).No leaks,will top-off with fresh mix tonite when i leave for work.Turns-out,anticipated problem never arose (hurray!).
Will bookmark your info/link,tho; if I don't need now,perhaps another will?
On another note; i've noticed (while searching/perusing) a near-absence of b.s.,flaming,etc..not-even much cussin'!
My joining this site has already been a pleasure,amplified by the lack of..ca-ca..
A real treat,Folks!
BTW; i took a quik turn across your 'grille/lites' topic..
Nice Ride..very-nice!
I've a bit of mechanical knowledge on a variety of things,just-not-much on this newer truck; it's my hope that perhaps soon i can also be of some benefit to an already-excellent Forum.
Again,Thank You.
Hey,THANX!
A real treat,Folks!
Again,Thank You.
BTW; i took a quik-look at your 'grille/lites' topic..
NICE ride,very-nice!
Ha........You haven't meet Jeff yet :cheers:
:D
:D
That's what I was thinking... :D
:D
+1 :D
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,130 Guests (See full list)
