Towing Questions
Guys ive miss placed my manual, What is the max towing capabilities for my truck. The configuration is Reg Cab short bed, z85 5.3 with the 4l60e z71 4x4.
Also when should i take it out of overdrive when towing. "this is my fist auto" Oh yea its a 2008
Give me a minute,But first of all a couple questions....What rear-end gear ratio you have?
And secondly....You said its a Z85 and Z71...Its going to be one or the other,not both.
So is it a Z71 or a Z85?
I have my book in front of me, but like like MSDale asked, I need the rear end ratio. The other way to find it is to go to here and download the tow ratings from Trailer Life magazine. There you can check the rating using the cab size, engine and rear end ratio. Or reply with the rear end ratio and I will double check for you. Regarding overdrive, I always press the Tow button when there is trailer hitched on, and I tow in 3rd gear.
my bad, It has the 3:73s, i thaught z85 was the tow package
Z82 is the towing package.
Yup, 7900 is your max tow capacity.
Cheers.
Hey,I said that already :crackup:
I was just confirming what you said with what I looked up and noted to be true :lol: . Not that there was any doubt, I just wanted to help :crackup:
Oh I know,I was just being goofy!! :lol:
just wondering if my truck would carry the same 7900 towing capacity. I have 08 Sierra Ex Cab 5.3L with towing package 3.73 gears.
7500 lbs if its 4wd,7700 lbs if its 2wd.
Having the extended cab takes a few hundred pounds off the towing limit, same with having the transfer case: another 200 pounds less.
i see you tow a 21 foot travle trailer. we are looking to get something similar. does your Sierra tow it with no problems? What the weight of your trailer? Did you do any upgrades to your truck to pull it?
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
