Catback Exaust
Chevy offers the catback exaust on their 2009 Colorado. Does this system offer a good bang for the buck. Also, is the sound annoying at hyway speeds. Ken
The stock exhaust on the Colorado is either 2 & 1/4 or 2 & 1/2 inches from the factory and flows very well. Unless you are planning some serious modifications (or just want duals) I would leave it be and focus on other upgrades.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
