2000 Silverado Weak Lock Remote
eskads
I have had this 2000 Silverado for several years. About a month ago, the remote started not to work unless I was very close to the vehicle...bad battery right?? I replaced the battery (and its in right side up, I checked) and even tried with my second remote that had always worked before...same story. They used to work from about 50 feet away. What's next?
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
