Disc Changer
I have a GM delco 12 disc changer and was wanting to know if I could still control it with an aftermarket stereo . I understand its a 9 pin connector, and was wondering if there is such a harness. Thanks! My truck is a 95 GMC sierra ex-cab 4X4.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
