Official #1 Post Whore
VMax2007
All hail the King!! :confused:
Can I get those girls in your sig under my Christmas tree this year! Please! :confused:
Can I get those girls in your sig under my Christmas tree this year! Please! :lol:
You'll have to ask them...But may I suggest a more comfy place? :confused:
Probably not, but here's the full size picture. :lol:
You are all Getting see below this year in your stockings...........
And the Ladies are coming over here to Spend XXX-Mas with Me..................... :confused::confused:
CONGRATS YOU POST HO!!!
Can I get those girls in your sig under my Christmas tree this year! Please! :D
Probably not, but here's the full size picture. :D
Thanks Dan. :confused:
Yeah, probably not under my tree this year. It's not in my nature to be "that good" that they'd show up under the tree. :lol:
Oh heck! They wouldn't be under the tree for long, before I took their 'wrappings' off and brought them out to play! :lol:
You would play with them?!?! :D:D
What would you play with them?!?! :D
Maybe Poke and See! :D:D
Or maybe.....Hide the mistletoe (as in your "missile" in her camel "toe"). :P
All hail the King!! :lol:
Can I get those girls in your sig under my Christmas tree this year! Please! :P
You'll have to ask them...But may I suggest a more comfy place? :D
Oh heck! They wouldn't be under the tree for long, before I took their 'wrappings' off and brought them out to play! :D
Or maybe.....Hide the mistletoe (as in your "missile" in her camel "toe"). :D
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
