New Guys With Some Questions
Hey whats up guys im Nate and i live in Mesa AZ and im driving a 2004 Chevy Silverado LS 2wd 1500. ok now to the questions so i want to lower my truck a little bit but i cant find anything to do it because my truck has the torsion style front suspension. i want something that will be good but that wont break the bank. any help you guys might have would be great. and i noticed that a majority of you guys lifted your trucks so please dont shun me haha.
Thanks
-Nate
I don't know how much either. Like you said...Most of the torsion bar topics you'll find on here are about raising, not lowering.
I'd imagine that if you dropped it more than 3/4" to 1", you'd be needing shorter shocks at the very least.
It probably wouldn't take much to try, and probably wouldn't hurt anything if done temporarily to test the waters. Park your truck on level ground and measure the ground to fender height...Then grab a 18mm socket and a ratchet, climb under there, and turn each screw one full turn counterclockwise. Go drive it around the block, park it in the same spot and measure again.
2wd with torsion bars? :P
Is it a crew cab? :D
EDIT: And to add to what Mike said, make sure you jack up the front end of the truck to take the load off of the torsion bars when you are adjusting them. This isn't as important when de-cranking, but is vital if you crank them back up. If you don't, you risk stripping the threads off of the adjustment bolts.
Yeah, that doesn't sound right. I didn't think a 2wd with T-bars existed....?
I think some of the crew cabs may have been, but I'm not sure.
it is defiantly 2wd and defiantly has the torsion bars on the front. it is an extended cab and im not sure if this helps but it came with the factory 20" wheels and someone said that it may be a 1500hd?? ive never even heard of that before
2wd with torsion bars? :D
Is it a crew cab? :thumbs:
Yup...They started that in '04 I believe.
so is that mean that the 1500hd thing is true?
    Dig Deep
    Dig Deep
  • Who's Online   3 Members, 0 Anonymous, 607 Guests (See full list)
