Shoulder Lean
Does anyone else have trouble w/ your trucks stance like when you look at it from the front it leans forward and to the left?
I guess its from always having weight in the drivers seat?
So i suppose the only way to fix it is to get a suspention upgrade? Or how can you fix it cheap?
crank the torsion bar up on that side. Make sure to measure, jack the truck up, turn clock wise I think a full turn, let it down, go for a ride and remeasure to the other side. Keep going till you get it right.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
