Please Help!
So here is my story:
I have a 2004 Silverado 2500 with 6.0 gasser. I drove from Edmonton to Fort McMurray (450kms) without a problem on Thursday. When I got there I put enough gas to go from 1/4 tank to 3/4. Went home and the truck sat til Friday night. It was -35C so Fiday night I went out to start it and warm it up and it wouldnt idle at all, just kept misfiring. I drove it up to the work mechanic shop, checked codes and it only came up at P0300(random misfire)and let it sit inside at room temp til Saturady night. Went in Saturday night and cranked it over and it still wouldnt idle and now the check engine light was not only on but flashing. I drove it to another gas station, topped it right up, added gas line antifreeze and fuel injector cleaner. Later that night I started it up and it ran smoother but still not perfect. I drove back to Edmonton Sunday morning and only got 200km before I was out of gas (DIC said I was getting 6.1 MPG). I twas puking out black crap from the tailpipe and still misfiring Filled it up after that 200km and and added more gas line antifreeze. Filled it up again in another 200km of highway driving when I got to Edmonton. So now Ive run 2 full tanks of gas through it, it isnt idling as bad but still has moments. Drove it this morning after being in my heated garage and it was fine, drove it this afetrnoon and it was acting up again, changed the plugs and no change.
I am unsure what to do. Is it a bad batch of gas? plugged cat converter? bad 02 sensors. I cleaned the MAF sensor but made no difference.
Please HELP ME
if your 04 has a FF i`d change it, can`t quite remember when they got rid of those babies. may want to check your fuel pressure, could be too high (indicating regulator fault) if there was any snow comming down during your drive i`d check your AF, if it is wet or has and ice in it toss her out...
Talk to the people at the gas station they may have had a driver drop diesel in the gas tank, If they did you will need to pump out the gas in you tank, replace the fuel filter and then fill the fuel tank up with fresh gas from a differant gas station. I have had it happen to my truck and my truck did exactly what yours is, but the gas station owner wouldn't admit that he had diesel in his gas tank
The Fuel filter is in the tank of the truck. Air Filter is brand new and I cleaned the Maf with sensor cleaner. Fort McMurray is terrible for putting everything in tanker trucks, I was at a station there once and the guy was filling the tanks and he still had placards on the truck from when he was carrying molten sulphur. He said he had only residue left than filled the truck full of gas. Just found it weird that when I start it, it seems to run okay for 30-45 seconds than starts to misfire.
How can I check fuel pressure?
so I figured out my code reader, here is what it says:
Fuel Sys 1 CL
Fuel Sys 2 CL
Calc load % 41.18
ECT © 93
STFT B1 0.78
LTFT B1 8.59
STFT B2 54.69
LTFT B2 8.59
MAP (kPa) 88.00
Eng RPM 2681
MAF (g/s) 106.00
TPS % 54.12
So Im assuming there is something wrong in the STFT which I found is short term fuel trim, and I have no idea what it means
  • 4 weeks later...
so I ran a whole bunch of gas through it, like 6 or 7 tanks and its seems to be running good. Pulled the downstream O2 sensors and cleaned them, bank 2 was covered in crap but bank 1 was clean.
Now (3 weeks later)I am getting the code P0430 (Catalyst System efficiency below threshold bank 2), doesn't seem to be lacking power but intermittently throws the code. So that is bank 2 O2 sensor, is there a way of testing the sensor because its like $250 to replace, or could it be that I wore out the catalytic converter due to the huge amount of gas that was being dumped into this side of the motor?
I also pulled both downstream 02 sensors again and started the truck, both sides seemed to have the same amount of pressure coming from the 02 sensor holes
this is the new freeze frame info:
Fuel Sys 1 OL-Drive
Fuel Sys 2 OL-Drive
Calc Load % 2.35
ECT© 94
STFT B1% 3.13
LTFT B1% -1.56
STFT B2% 3.13
LTFT B2% -1.56
MAP(kPa) 37.00
Eng RPM 568
veh speed km/h 0
MAF (g/s) 6.00
TPS % 9.41
So they same thing that originally happened a month ago, did the same thing again, basically the exact same story, I can seem to figure this out, problem went away and now repeated
P0300 Random Misfire Detected;
Fuel Sys 1 CL
Fuel Sys 2 CL
Calc Load % 2.75
ECT © 62
STFT B1 % 0.78
LTFT B1 % 0.78
STFT B2 % 51.56
LTFT B % 0.78
MAP (kPa) 40.00
Eng RPM 622
MAF (g/s) 8.00
TPS % 11.37
    JohnRoy
    JohnRoy
  • Who's Online   4 Members, 0 Anonymous, 655 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
