2003 2500hd Steering Problems And Tire Wear
I have a 2003 2500 hd i have a clunking sound in the steering. i had the recall work done on it 3 times never has stoped the clunking sound. i also get tire wear on the inside of the drivers side front tire. I jacked up the front of the truck and noticed the front wheels would move side to side. it does not seem to be the upper or lower ball joints problems or the wheel bearings. Its something in the steering. i have worked on honda's for over 15 years. i got the truck to haul my race car but the race car is more reliable than the truck. by the way if you use honda civic exhaust manifold studs it will fix the manifold bolt breaking issue. i have taken it to many dealerships but just cant get a good fix is there any good fixes for this problem
i had the exact same thing going on with my 02 finally figured out when i had tires put on they lined it up and didnt tighten the nut tight enough on the upper a arm it wasent much more then hand tight hope this helps
Check out http://www.cognitomotorsports.com/store/ they may be able to fix.=brian
