Impossible Seperation
mychevyvan
Alright pros,
I gave this to the Engine and Drivetrain crowd a week ago because I could not get the transmission to seperate from the motor in my 97 Safari. They asked all the obvious questions I already asked myself many times and yes, I am 100% positive I have disconnected everything! I have been working on this for hours, for days and I am looking for anyone who may have had a similar situation and found a solution that they are willing to share. I asked a very busy third generation transmission shop owner if he had ever seen such a thing and he had not. The van is stuck in my garage now and I am more broke than when I started, so taking it in is NOT an option. Oh and did I mention I am using my wife's side of the garage for this project? My biggest mistake so far! I don't want to wreck anything to seperate this pig so I am begging for your help! How do I resolve this dilema?
Just shoot me. :)
That sucks man. Wish you were closer, I'd drink beer and beat on it with you.
Umm, Mike, you need to learn to take this to a different site. :)
OP, I missed your other thread but have you tried applying force at the far end with a ratchet strap or come-along? I'm not sure what you'd have available to anchor it to other than another vehicle but the additional leverage might help. :)
lol....
As for the topic at hand...He's tried all the stuff I can think of off the top of my head, and one of them has always worked for me.
I hope it doesn't come to that! Thanks for the sympathy tho.
I have not tried pulling it straight back. I'm not sure what I would hook to on the trans, I can pull back from the reciever hitch if you have any ideas where to snag the trans. I have tried prying up, down, left and right. I swear I will need to replace the motor mounts already!
Thanks for thinking it through with me.
If you had a nylon strap you might be able to wrap it up in a way where it wouldn't slip off...hook it up with a come-along or something at the other end...Connected to the frame or something...And start cranking away.
Of course, I wouldn't want to be around if that strap came loose :)
Umm, Mike, you need to learn to take this to a different site. :D
I was thinking side to side but you've already done that, unfortunately. :)
It's worth a shot. :)
Just trying to work out of way of executing your idea.
Of course, I wouldn't want to be around if that strap came loose :D
It's something I will give a try...carefully. :lol:
It's worth a shot. :lol:
Thanks for the encouragement!
Here's another idea if you've got the space...Tie the transmission off to something in the driveway (like another car frame), let it down onto the wheels, and get a couple of people to rock the whole van forwards and backwards. More hassle than the comealong method, but probably a lot safer if the strap comes off under tension. Plus, you'll have a LOT of energy tugging on it...Basically the weight of the whole van.
Seriously...I'm at a total loss on this though. I for one give you an A+ for patience. I would have started it up and dropped in gear at least once by now...Just to see what happens. :D
Of course, I wouldn't want to be around if that strap came loose :lol:
Seriously...I'm at a total loss on this though. I for one give you an A+ for patience. I would have started it up and dropped in gear at least once by now...Just to see what happens. :lol:
Thanks for the idea. I talked to a retired mechanic today and his thought was that the alignment pins are steel and the trans is aluminum so when exposed to the road salt levels the last two years I lived in SD the two metals may have reacted. He said a good shot of liquid wrench overnight cures alot of back aches before they begin. I will give this a try and Saturday afternoon two guys who work for beer have offered to remove and replace it if I buy a case. If you can make it here, I will get one for you too. Then, if they don't succeed, I'll have enough man-power to try it your way. Shoot, we can even drop it in gear and give it hell if that doesn't work! It could be more fun than the 4th of July! :thumbs:
