C7 lights
General Lee 01
This year we decided to go with C7 lights and they get really hot. I was wondering if that's helping our tree die.
Anybody else (Who has a real tree) have these kinda lights?
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
