Upper Intermediate Steering Shaft Replacement
hey guys, wondering if all of you that have done the shaft replacement to stop the clunking in your steering wheel could give me some info...
i have an 04 silverado 1500 z71 that has the clunk in the steering wheel..so i have a few ???'s
where can i get a quality replacement?
is it an easy task to handle on your own?
does it really fix the problem?
im sorry for probably double posting some info here but the search feature on my account doesnt work... it comes up error every time i use it and i dont feel like browsing through the millions of posts...
so any info you guys could get me would be greately appreciated!
thanks, steve :rolleyes:
The product is in my sig for the upgrade once my truck is out of warranty. It is the last on the list.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
