Anyone Into Boats? Post Your Pics
illMATTic
  • Replies 83
1993 Larson 200SEI. 5.7L with a 2-barrel carb. She has an 8' beam and is super stable. With ten on board she'll still run close to 50 MPH.
My father-in-law has a 41' Morgan OutIsland sailboat.
I sold mine last Summer but here is a pic.
Do not. I repeat do not ever ride in a boat driven by this guy. I did once and lived but I am not really sure how.
Here is a father and son project boat. Me being the son. Lots of work. Two new motors and some cabin work and tons more work that can be done to make it perfect. 1987 Chris Craft Stinger 4150
1977 Glastron CVX-20 Jet boat
455 Olds
Berkley Pump
All new interior
Father/son restoration project me being the son. Its my boat now, so he can have the room for the new Factory Five car
That's cool!!
here is a bigger picture of the boat that is better. Here is my dads 2001 carver 466 motor yacht. its got twin volvo diesels and the works.
Kyle, where does he slip it?
That question is a little personal don't you think?
Oh, you mean the boat :D
You know you liked it. Everybody had fun (after we found them all) except for John who has finally gotten that pesky cast off. He may never forgive us! :D
Jeff, this picture was taken on one of our cruises to Lake City. As for where the boat is normally, that would be Bayport.
Ahhh, the St Croix. :D I am sure I have seen it many times then as I spend all summer on the St Croix. Usually between Hudson and Prescott and many days at Kinnikinnic.
