Quick Question About 02 Auto Trans
During an auto trans filter and oil change, I had to bend the shift linkage out of the way to get the pan down. As much as I didn't want to, the torx screws were already shot and weren't coming out (rusted). Anyway, I bent it back to where I thought it was but the shifter in the truck was very tight to move. I played with the linkage until I thought it was back to normal and now it seems to work fine. However, I was thinking about it today, and wondering if the shifter is putting the shift linkage on the transmission completely in gear. Its shifting normally. My question is this, when you move the shifter in the truck and it clicks into reverse, then clicks into neutral and then clicks into drive, is that click from the shifter (in truck) or is that the actual shift arm on the transmission clicking? As an example, if the shift was disconnected from the transmission all together, would you still have the click sensation in the shifter from Park to reverse to neutral or would the shifter move freely up and down?
The reason I ask, if it is the actual shift linkage on the transmission that gives the click, then I know for sure that the truck is all the way in gear.
Hope that makes sense.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
