Pinion Bearing Preload
zaac
I put in new bearings and seal and was supposed to set preload at 20-25 in-lbs. I got impatient and ended up blowing right through that and ended up at 31 in-lbs. Is this gonna significantly shorten bearing life? It's a 8.625 rear end. Thanks in advance...Jack
I pulled out the carrier and rechecked the pinion preload without it and it was at 24. From what I could find it should be 14-19 in-lbs so I'm gonna get a new crush sleeve on Monday and do it more carefully. I've noticed there's not much help around here. How come the Ford website has a half million members and there's only 50k here?
I dunno, go ask the ford guys. Maybe its because many more fords guys have problems they need help with. And maybe cuz most Chevy owners actually don't have as many problems with their trucks as much as the FORDs (Fixed Or Repaired Daily) do. I know aside from the steering shaft clunk I used to have, I've never really had any problems outta my truck. My truck is a beast, thats why I call her the "Green Monster" (that also explains my avatar). :dunno:
I dunno, go ask the ford guys. Maybe its because many more fords guys have problems they need help with. And maybe cuz most Chevy owners actually don't have as many problems with their trucks as much as the FORDs (Fixed Or Repaired Daily) do. I know aside from the steering shaft clunk I used to have, I've never really had any problems outta my truck. My truck is a beast, thats why I call her the "Green Monster" (that also explains my avatar). :)
I new if I got ignorant I`d get a response. :dunno: Now that you put me in my place do you know anything about rear ends. I`ve been babying this truck but it`s still breaking me. Guess I got a lemon. Tranny, 2 fuel pumps, encoder, 4wd buttons, front hub, ball joints, U joints and now both diffs getting rebuilt. I`d imagine the TC won`t be long. 140k and only the last year has been off road and gentle off road at that. I`m starting to see why the Fords have been no. 1 seller since `76. :lol:
How long have you owned the truck? Everything you are talking about seems like they would all be linked to severe duty towing. The previous owner must have literally worked the shit outta that thruck. Think about it, if you were constantly towing over 8000lbs wouldn't that stress the tranny, suspension, rear end, etc. ?? And as for the rear end, yes I did have problems with my rear end. It was making a slight clunking sound (which I just thought was a suspension bushing or something) and it ended up being my pinion bearings were bad. But mine went out at less than 80,000 miles (which the dealer said is EXTREMELY rare, the rear end going out at any mileage on these trucks he said is pretty rare) and luckily my extended warranty covered the entire cost of the repairs. But I didn't even realize anything was wrong because it still drove, functioned and even towed perfectly fine. Only thing was the slight clunking I mentioned,(mainly on bumpy roads) so I brought it in to have the suspension checked.
Actually the truck was never off pavement and driven easy its whole life. I bought it of my Dad so that's why I know the history so well. I bought it a year ago for work which is mostly offroad but at an easy pace. The Fords at work break down too, I just said that to get some attention. :P The bearings in the rear end were fine, it was the clutches in the G80 that were wasted. I'm sure the truetrac will outlast it if I ever get the dang preload, backlash and pattern right. Should get the front diff back tomorrow from the shop. Hopefully they find something that is causing the noisy 4wd.
Too much preload will kill the bearings. Your going to have to tear the end open and replace the crush sleeve.
That's what I figured so I re-did it again today and got it right where I wanted it. Hopefully she'll last. My Dad even has some Amsoil 75-90 gear oil for me. :thumbs: Thanks for the help.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
    • Thks, and actually it was my bad, because here in this post there is someone showing the correct wire position as well. My bad... But thank you a lot with the help as well. I was able to find and buy a 10 channel VPM that came from a sister silverado of mine. The same year, same mode, same trim, same everything. 2022 Silverado 1500 LTD LTZ (pre-refresh). I also found to buy just the bottom mirror part that has the cameras, so way cheap than the full mirror. + a used front camera. I did test everything together, cameras, cables and the VPM.... everything worked EXCEPT my original Bed camera and the backup grid lines. I think the reason is because now I need to do the VPM reprogram. I sent a msg White Automotive & Media Service to confirm that it is the problem and that they can do it service for me case.   Once I get it 100% done I will post here result....
