Smelling Antifreeze
Lately I've been smelling antifreeze when I have the window down. I can't smell it in the cab with the window up, even with the vent on. There are no puddles or leaks under the truck and my radiator level appears fine. I've tried looking around the engine and radiator fittings, but I don't see any evidence of a leak. Any ideas?
Hard to say for sure. Possibly a seeping water pump, heater hose, or Intake manifold gasket leak? Watch closely and see if the coolant level is dropping slowly over a week or two. That seems to be how the intake leak goes. My 01 did that and there was never a drop of coolant seen anywhere. Also, make sure no coolant is making its way into the oil. I'd get it checked out before it becomes something more serious.
Thanks for the ideas guys. I am the checker outer- I can't afford to have someone look at it unfortunately. What would be the easiest way to check for coolant in the oil? I did look at my oil when I changed it a few weeks ago because I had just started smelling it, but I didn't notice anything out of the ordinary.
As for the intake gasket, is there a way to check that? I don't have a problem replacing it, I'd just rather be sure before I devote the time to it.
The easiest way to check for coolant in oil is to check dipstick and oil cap for foam/milky streaks. another not so easy way would be sending your oil off to a lab to analyze it.
I would wait until the leak got bigger to find out if it is the intake gasket. But as zembonez said it could be the water pump or the water pump gasket but that leak will get bigger too.
But first and foremost, you need to rule out the head gasket by checking to see if there is coolant in the oil.
Fantastic. I would have noticed milky streaks and definitely saw none, either in the oil or on the cap. I'll check again just to make doubly sure, but I think I'm in the clear there, thank god.
A pressure test may show you where the leak is. The water pump and the intake manifold gaskets are common places for a leak to occur and relatively easy and inexpensive to rectify if you are a do it yourselfer. Heater core leaks are easy enough to detect but can be a real challenge to get to. I would track down the source ASAP as a coolant leak can escalate rapidly and never at a convenient time. See if you can borrow a pressure tester and you can perform that test in 10 minutes.
I'll be checking the heater core too, but it was last on the list because it's inside the truck. I've had it go out on me a few times unfortunately.
As far as this pressure test goes, how can I do that? Are you talking about one of the radiator pressure testers? What is the preferred method?
Yes, same tool.
On my '94, 350, I would have problems with the quick connect coupler on the back of the intake manifold.
bbwb
bbwb
yeah, and touch THAT thing with a wrench, and it snaps right the hell off. :mad:
Had the same problem with a water pump leak. kept smelling Aunt Jamima in the cab with me with the window down. Didnt realize it was the pump until it started puddlin up the driveway.
If you go thru all the ness. checks and find that it is none of the above, then I would start lookin at the car you are following all the time. Mabe he's the one with the leak!Good Luck :cheers:
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
